warm start problems
Topic Started: Tue Apr 10, 2018 11:44 pm (159 Views)
nick.m
my sons 190e is being a bit of a pig to start when warm, from cold its fine no problems but when warm it wont start without giving it roughly 3 quarters throttle and if you let off the throttle all together when it does start it dies straight away so you have to keep a few revs on for a few seconds then its ok ,once started hot or cold it runs just fine with no issues, any ideas folks
Hi Nick. It will help to know which engine the car has.
Stu.
nick.m
2.0L auto stu
optimusprime
My problem was the same only the m103 engine ,. I changed the coil, along with the engine temperature sensor .
bindse
Hi
Had the same issue a while back. Changed the gasoline injectors and the O rings and it starts in secs every time.
If the injectors are the originals or just old and worn they leek and dont promt the start when warm.
And of course new coil and spark plugs, is a must...
cheers
Edited by bindse, Fri Apr 13, 2018 10:12 am.
